Can't get opacity in VRayLightMtl to work with RT CUDA
  • Can't get opacity in VRayLightMtl to work with RT CUDA
    I wanted to try and render some candles with Vray RT and VRayLightMtl where the flames are made from a plane with a texture. The flames however come out with black background as if opacity does not work even though I have a texture in the opacity slot. It works fine with Adv. I took a quick look at the docs and it says that VRayLightMtl is supported apart from the direct illumination option. Please see screenshot below:
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    The "multiply color by opacity" option is still not supported in GPU. Is this your case?
    Peter Matanov
    Chaos
      No, I'm not using "multiply color by opacity". I've just got the same texture in the "Color" and "Opacity" slots.
      Aleksandar Mitov
      96GB DDR5
