Both denoisers at the same time?
  • Both denoisers at the same time?
    I ask me, could it be possible to switch between both denoisers if a rendering is done? Each of them has advantages and for example it could be great to save both results and combine the results in postwork.
    Most I use the V-Ray denoiser, but some times I see noise artifacts at edges like at this example and than I would like to use the Nvidia denoiser without to rerender the scene.
      I second that request. Would love to use both. It would also be great if I could dedicate a gpu to the Nvidia denoiser so that it doesn't eat vram which I need for rendering. Using the denoiser with the gpu attached to the monitors wouldn't be a big problem, right?
      Add Your Light LogoCheck out my tutorials, assets, free samples and weekly newsletter:
      www.AddYourLight.com
      Always looking to learn, become better and serve better.
        Great idea. If I render complex scenes than I use my two 2080ti only and the 1080ti is reserved for the system display use only. Using it for denoising instead the 2080ti with heavy load could be help a lot.
          just catching up on Vray 5 and new frame buffer seems to be missing a few things. (frame stamp!?)
          Marcin Piotrowski
          youtube
          CGI OCIO config 04
