After converting a .ply point cloud to a .vrmesh. Loading in Maya and applying a vertex color I receive this error.
// Warning: line 1: V-Ray : Texture "__vray_vertex_channel_texture_0_VRayVertexCol ors1 " of type "TexMeshVertexColorChannel" is not supported. //
The point cloud renders properly in CPU mode. GPU mode creates a black image, but the alpha is there. So it seems the point cloud does load but there is a limitation with the "Vray Vertex Color" node with GPU. Thank you.
Thanks for the details tweezlednutball
I'm looking into this now, could you please upload a simple setup showing the issue if possible?
Vertex color seems to work here, this is probably specific to your setup
