Proxy Point Cloud GPU
  • Proxy Point Cloud GPU
    Would be nice to be able to render point clouds with GPU.
    Thanks you!
    Hello! tweezlednutball
    Can you share more information about this request? DCC used, use case..etc so that I can investigate and make a request
    Best,
    Muhammed
    Muhammed Hamed
    V-Ray GPU product specialist
    chaos.com
      Hi Muhammed,
      After converting a .ply point cloud to a .vrmesh. Loading in Maya and applying a vertex color I receive this error.
      // Warning: line 1: V-Ray : Texture "__vray_vertex_channel_texture_0_VRayVertexCol ors1 " of type "TexMeshVertexColorChannel" is not supported. //
      The point cloud renders properly in CPU mode. GPU mode creates a black image, but the alpha is there. So it seems the point cloud does load but there is a limitation with the "Vray Vertex Color" node with GPU. Thank you.
        Thanks for the details tweezlednutball
        I'm looking into this now, could you please upload a simple setup showing the issue if possible?
        Vertex color seems to work here, this is probably specific to your setup
        Best,
        Muhammed
        Muhammed Hamed
        chaos.com
          Hi Muhammed,
          I sent you a private message with a link to the Maya scene.
          Thanks!
