It is not impossible, and we are thinking about it, however it is quite a bit of work.
Thanks Vlado & Carlos (from iToo) I added this to the wish list because it certainly seems apparent that VRAY RT is an important part of many artists workflow. It also seems that RT will eventually be used as a production renderer by more & more people, like iRay is. So it seems that being able to use RT for popular plug-ins like Forest Pack is important. Thanks again for both of your responses. You both represent excellent companies!
For the next service pack, you can convert ForestPro to regular instances and that will work fine.
We also have a prototype implementation in the nightly builds that translates ForestPro directly without explicit conversion, but there are still some issues with that on the ForestPro side and it wasn't stable enough to include it in this service pack.
Here is another teaser done by Peter Matanov (our Q&A guy):
On the whole, instancing (not only through Forest Pro) allows you to render much more complicated scenes - one of the test arch viz scenes here had over 58 million polygons...
