couldn't see anything about this so i thought i's ask. can you use vrayedgestex with chaos scans? Can't see an option to input it anywhere
chaos scans with vrayedgestex?
Originally posted by lukepenry View PostI just saw using the vray bumpmtl it can be done------------------------------------------------------------
V-Ray 6.20.06, 3ds Max (3D Studio thru Max 2025), GIGABYTE X570 AORUS Master Motherboard, Ryzen 9 3950x CPU, Noctua NH-D15S CPU Cooler, 128 GB G.SKILL Trident Z Neo DDR4 Ram, NVidia RTX 4090, Space Pilot Pro, Windows 11, Tri-Monitor, Cintiq 13HD
Autodesk Expert Elite Member
- Likes 1
I'm not quite sure what the question means and what is the use case, but apparently it is not rare if two users simultaneously are needing it. So what is the case? The VrayEdgesTex is just a texture and can be put in every texture slot, what it means "and saw that there was no place for it " ?______________________________________________
VRScans developer
