Fabrics overly bright
  • Fabrics overly bright
    I had different fabric materials tested out and these are not working and seem to be emitting light or are just overly bright. I made a video so you can see for yourself:
    https://drive.google.com/file/d/1qmD...ew?usp=sharing
    https://drive.google.com/file/d/1fKZ...ew?usp=sharing
    Fabric 12
    Fabric 4
    Fabric 6
    Working with 3ds max 2015, vray next nightly 28067 and GTX 1070, driver 390.77 (although with an older driver I had the same problem)
    Am I doing something wrong here?
    Add Your Light LogoCheck out my tutorials, assets, free samples and weekly newsletter:
    www.AddYourLight.com
    Always looking to learn, become better and serve better.
    btw Next advance (is it still called like that, the CPU only variant?) also gives me stranges results, although not as overbright as GPU
    same thing in material editor btw
      can you give the name of the material?
      it looks like bad data are involved, may be the material is broken,
      ______________________________________________
      VRScans developer
        material names are as mentioned above
        fabric_0012.vrscan
        etc
          thanks for the report, it was a compatibility issue introduced few weeks ago, affecting only certain materials, check the nightlies tomorrow or monday
          VRScans developer
            cool. thanks!
            in this case you should check all the latest fabrics maybe?
            found that transparency doesnt work with fabric_0011.vrscan in GPU
