Hello.
I’m experiencing something a bit odd: my VFB history doesn’t keep more than 1 saved image, i.e., every time i try to save a new one it just replaces the last.
Can you guys help me out with this?
Corona 1.5.2
Thanks in advance
Hello.
Corona 1.5.2
Thanks in advance
Is it a huge render?
It could be an issue with missing RAM or HDD space.
There is a “size on HDD” setting for this in System > System Settings.
Thanks for your reply Maru,
The image is 3000x 2000.
Neither RAM nor HDD is tight on space (32GB and ~200GB free, respectively).
Any other possible causes?
Still in need of an answer guys, i’d be grateful if anyone can point me a solution.
I have just tested this and it works fine here. Can you share any more details?
Does it work if you render in lower resolution?
Do you have a lot of render elements added?
What is your “size on HDD” setting in System > System Settings?
Changing this solved the problem.
Changed from 512 to 2048.
Thanks!
