store and keep renders in History
I stored some renders in the VFB history and closed Max. Later, I opened the same file and wanted to check those renders but they are gone. Is there any way I could keep them in the history? It’s like Vray VFB history that I could just keep them and delete then when I don’t need any more.
regards
Unfortunatelly, history is valid only in the curent session. Actual files are saved to the disk, but there is no possibility to load them into VFB later. Hopefully it will be changed in the future.
Thanks for your reply, romullus. I hope that feature will be implemented near future, it’s useful for me.
I’m new to Corona, and this is something that I’m surprised is not in the software.
I don’t finish working my projects in one day - they are created over days and weeks.
Is this now possible (some way I’m not aware of) ?
Thanks.
No, it still has not been addressed.
I have created a new feature request in our system for this.
Cheers,
Rowan
(Report ID=CRMAX-17)
That’s great news.
But I’ve also learned that it seems only so many files will be stored during a session.
I don’t know what the limit is, but it might be a hard disk size limit somewhere ? I seem to only be able to store 2 or 3 of my images to the history, once I try to save a 4th image, one of those other 3 images gets removed…
I’ve been using V-Ray for 10+ years, and I am loving Corona, it’s lovely and not complex for beginners (like me) - but I have to say, that I’m very surprised by this side of the software.
I’d have expected anyone to have highlighted this limitation by now, especially as this software has been around for a good few years.
As I say, I’m loving Corona - not trying to slag it off, just help improve it :smiley:
Yes, right. Have a look at Render setup → System Settings → Render history and A/B comparison → Size on HDD. Since history items are actually Corona CXRs, they get quite large and the default there (2GB iirc) is way too low.
Good Luck
Has there been any movement on this? Is it in the roadmap for new features yet? I really liked how history was implemented in Vray and would love the same functionality here. It is so useful for comparing small changes, which is a common request from my clients.
On the roadmap, we are focused on 7 just now (and it would be too late to change what is planned there), and we won’t be reviewing “Ok what shall we do in 8?!” until 7 is released as a result of the focus on 7. So the time to check for updates to the roadmap will be after 7 is released and we go through all the requests and pick what looks like good candidates for inclusion in 8, and good candidates to go on the “pool of ideas for in the future”.
So, keep the suggestions coming, but don’t be alarmed / disappointed if the roadmap doesn’t update for a while yet :smiley:
Ok, thanks for the update. Would be great to have this feature implemented at some point, it really was a very good workflow tool when using Vray.
Will keep an eye on the roadmap once version 7 has released.
Well, actually - if your max crashed , you can still find the History images back in
Users.…3dsMax...\plugcfg\corona\history\ folder as openable .Cxr files, this just helped me a bit with some test renders I had in a History row.
This tip save my life and my project, thank you so much.
path to the backup history complete:
C:\Users"your user name"\AppData\Local\Autodesk\3dsMax\2021 - 64bit\ENU\en-US\plugcfg\corona\history
open the archive .CXR in image editor and save your image.
