1.5 Proxy export crash on numerous files
I’m finding that proxy export seems to crash on certain models even though they are around a reasonable 150mb and with no connections or history on the object.
Here are my settings:
V-Ray creates a vrmesh file then Maya will crash, sending off an error report. However the vrmesh is corrupt because it is able to import into Maya (albeit a single tri poly) and when I render with it, it is empty.
[2011/Nov/7|10:44:01] V-Ray: V-Ray for Maya version 1.50.SP1 from Jun 8 2011, 21:26:54
Maya 2012x64 SAP 1
There was a bug with this in the original build; try a newer nightly or stable build - it should be fixed.
Thank you Vlado, the August version is now rock solid. I was a bit hesitant in changing builds as a few weeks back I had to switch back to an earlier build because of some stability issues.
However I found that I was able to fix the stability issues by simply disabling Aero in W7. I don’t know why but it’s worked - Maya doesn’t crash after finishing rendering anymore.
