Compare the two images.
Whether I use render slaves or just my local machine for netrendering does not make a difference.
Only difference in render settings is that the netrender flag was ticked.
Netrender
Rocalrender
No lights or materials defined in the scene, lighting occurs only through
GI Environment (skylight) override in the V-Ray:Environment settings.
When I switch the Default lights off in the Global Switches section the renders look the same.
