10 Server Limit
I have two vray licenses, three local workstations and 10 remote servers. Max 8 and Vray 1.5rc2 (with the new cgauth60.dll) are loaded on all 13. I am trying to render on all machines but Vray only renders on 10, even though it sees the others in the DR Settings box. Any ideas what I am doing wrong?
Craig
PS. I’m running Windows Server 2003
this is a limit in the vray software license. You can use more than 10 when you get your dongle :slight_smile:
You need Windows Server to use more than 10 machines.
look on his PS tricky :smile:
aphex79: That’s disappointing. How certain of this are you?
tricky: I have server 2003.
yup: read this: http://www.chaosgroup.com/forum/phpBB2/viewtopic.php?t=16260&highlight=
Thanks for the link, aphex79.
The limit is the software.
OK, so the software license is the problem and I have to wait for the dang dongles to access all my machines. And since I can’t ask the forbidden question about when the dongles will start shipping lest I should incure the wrath of Da Elf and others, I won’t ask. But does anyone know if Vlado takes bribes? :slight_smile:
LOL. That’s one of the funniest things I’ve heard in a while. You should make it your tagline.
On that note, Vlado is very accomodating. Write Chaos and I’m sure theyll try to work out a solution for ya. :wink:
I was very comfortable here with the software licenses, almost not thinking about the small green thnigs, and know what, last week they arrived, the 2 dongles I mean :smile:
So they are being shiped and I’d guess they’ll finally reach every hidespot.
Cheers
Fermí
