Hi, i have just moved over from redshift for a project and looking to create this result where it rendering in a sphere shape with empty corners. Currently in the camera settings, if i set it to spherical panorama it still renders the corners and not a sphere shape.
Thanks!
Hi you probably want to use the “fish eye” mode. Here is how it looks:
If you disable the “fish eye auto-fit” you can adjust how far from the edges you want your image to fit. In my example with the auto-fit it takes the whole frame.
ah yes most likely thank you for the quick reponse!
Actually i cannot see this option in Vray GPU?? is it supported? because its actually 100% needed for this project.
If this is not supported which it looks like it isn’t. is there a workaround of some kind?
Hi it is not supported in GPU. I found a possible workaround for this. It involves using the OSL from this web site: Fisheye OSL lens - OTOY Forums
I have tested it and got these results:
You can try it yourself as a workaround but keep in mind this not our development nor webpage. I am just sharing information.
