2.4 Vrayfur level of detail
Just wondering what the values mean in terms of scene units for Start distance and Rate?
They default at 1000, so is this inches or feet or?
(Working in feet with decimal inches.)
Thanks a lot for adding this BTW.
and only from camera or also from a persp view?
They are generic scene units; as is the custom, we forgot to specify that the spinners should display in the current scene units :slight_smile:
It’s fixed for the next nightly build and we’ll patch it on the site too.
It works both with camera and perspective views.
Thanks for the explanation 8)
It’s not the exact subject but I try to use the VrayMultiSub Tex with VRayFur but it don’t work. I put a Material or a MaterialByElement modifier but no effect.
Is there a way to have random colors in VrayFur?
You can use a very fine Noise texture.
Could you please tell a bit more on this method? I was also wondering about the question fredodingo asked…
thanks in advance
Did you mean a few scattered colors texture? Or is it a specific effect that you want to achieve?
