Vray Dirt Units
Hi all,
Has anyone been able to use succesfully VRayDirt when your units are metres?
Currently when adding streaks you can’t go below 1 in streak size, this 1 equates to 1 metre, obviously not helpful.
Thanks in advance,
Jason
Only the Radius parameter is dependent on scene units and it can be a decimal number.
Please check streak size @hermit.crab , that doesn’t go below 1, so that’s 1 metre in size..
Thanks,
Jason
Yes, I know it does not go below 1, but that doesn’t necessarily mean it is in meters. Also, the Streak Size parameter controls the thickness of the streaks, not their length. Read the docs page I sent.
So 1 being 1 metre, that was the issue, not to worry it’s just how it is.
Thanks,
Jason
