2 VRay Frame Buffer within One 3ds Max
I didn’t know that it’s possible so far. :smile:
Why would it not be possible? Each instance of the V-Ray renderer in 3ds Max can have its own frame buffer.
I just run only one 3ds Max.
Yes? I said instance of the V-Ray renderer, not 3ds Max; f.e. if you have V-Ray set as production renderer and it shows its frame buffer, if you use the MaxScript render() command, this will create another instance of V-Ray with its own frame buffer.
How many VFB is possible? I didn’t use maxscript command. I just used render preset of 3dsmax.
