I have a pendant, with some objects with 2 sided material, each with a sphere light inside (very typical) - on the left is a mirror wall - but you can see the reflection of the 2sided material is weird.
Is this a gpu limitation?
Hey @AlexP
This is not expected to happen, could you please attach your scene? or a simplified version?
I will make sure this gets solved
Best,
Muhammed
Thankyou I will save a simplified one
Obviously in a stripped down one it works perfectly haha
@Muhammed_Hamed if there is a way I can send you the whole scene confidentially I can do that.
Sorry for the late reply, drive should work fine
Send it over to muhammed.hamed@chaos.com
Best,
Muhammed
