Has there been any ..development on vary’s ability to render 2-sided with a vary material…??
You can get it to reflect using a standard material ..with a vary mat as a reflection then 2 sided but not using a regular Vary material…
And it like triples the ..render time…
Andy suggestions???
isn’t vray material always two sided?
btw it’s vray, not vary ![]()
yeah but try it…
yeah but try it…Like make a reflective object…flip some faces and try to correct it ..in the material…
It be sweet to fix..
I have HUGE models …tiny flipped faces
i have expereicned the same problems w/ vray materials and flipped faces. :S
me too ![]()
well is it a flaw in the software…that …doesnt make sense that it forces 2sides with every object but cant render ..accurat reflections??? on a back side…
ok doke…caus Im useing glossy reflections and it taking 2 times as long as useing a vray material …
ok doke…
am I missing somthing…?
You could always use a double sided material and put a copy of your vray material in each slot.
V miller
