3.20.01 Render Elements Behavior
Sorry if this is the wrong forum, if so please feel free to move to an appropriate one.
Some questions about render elements in 3.20.01 and Max 2016.
When I have the VRFB enabled, whether rendering locally or via our farm, the render elements are not saved - not as separate files nor embedded in an EXR. Is this normal behavior?
Additionally, when rendering to a farm with Deadline 7.1 (without the VRFB enabled for render pass output), the initial frame per node renders the passes just fine. Yet when iterating frames, the subsequent frames are all black. I can overcome this by checking Deadline’s “Restart Renderer Between Frames” option. Again, is this normal behavior?
Thank you for shedding light on these occurrences.
For the first question - it’s normal. The elements must be saved through the V-Ray VFB options (either the raw file output as .exr or .vrimg, or through the “split channels” option). You can always turn off the VFB for farm rendering though.
The second part with the black frames, I’m not sure. Will have to look into it.
Deadline recommend putting “Restart Renderer between frames” on. It solves many issues with VRay and Deadline. It’s a max issue technically somwhere apparently…
Thank you Vlado and Dave!!
