3dmax2011 - slate material editor
Hi, im using max2011, and also the slate material editor, so far so good, but the problem is when i create a bitmap ( inside the slate ME) and if i want to put it on the environment , drag&drop doesn’t works (like the older version of the ME), Its a bitmap is like any other else but its not yet apply on the scene so it isn’t show on the scene materials list. ¿Anyone knows a walk around to this? I could create a new bitmap from scratch on the environment but this is not the idea.
Another thing is when i load a material library or open the scene materials list it shows as Icons and Text, i would like the make the default shows only as a Text ( big bitmaps takes ages to “rendering” on previews inside slate ME)
Any advice?
pedro
Drag&Drop works, just drag the output of the bitmap into the environment slot. :slight_smile:
hi snipeyX, i’ve tried your suggestion but it ended up creating another map, nice trick btw :stuck_out_tongue:
