3DS MAX Animated Fan
I animated a fan turning in 3DS MAX, but the animation doesn’t carry over. Am I missing something?
If you exported a vrscene, did you select “export animation” and the relevant range ?
I live linked it. So, I have to export. Thank you!
The live link should work too, but you need to change the time in the 3dsMax timeline.
Can you elaborate. I have my timeline set up in MAX? I just need the still to have motion blur on it.
You didn’t mention motion blur in your original post. In that case you might actually need a vrscene, but I am a bit behind on that, so not sure.
If you need a still image with applied Vantage Motion blur on it (you know it is a post effect MB) then activate the MB in the Render settings in Vantage and set a sequence of 2 or 3 frames. Vantage will apply the MB on the second frame.
