3ds Max cannot save preferences in Max 2026
Hi
Recently I had this issue in 2 computers, one with Windows 11 and other in Windows 10.
I have made some tests and it seems that installing V-Ray 7 causes max 2026 to stop saving preferences, its really odd because in an old PC where I have Windows 11 this happened when I install SiNi, but in my main PC with Windows 10 it happens when I install V-Ray 7.
I still have to do more tests with Phoenix too, Does someone has similar issue?
You can follow the case in this thread on Autodesk forum.
Ok I have double checked in 2 computers and it seems its Phoenix Ill try to install the latest nightlie to check if that its solve.
A colleague will investigate and answer you in your other thread.
Thanks, already solved with latest nightlie experimental_33467, thanks
