3ds max cannot save preferences
Hi
I was having this issue with max 2026, I finally found that Pheonix is causing this issue, Im using 5.24.03
Ill try to installa the latest nightlie to see if this has solved
Can’t see this in a quick test here - 5.24.03 is a nightly build. Can you try with the Official ? or latest Nightly?
Which properties and options you are changing from the Preferences? To try the same here ?
Thanks for answering I didnt have the time to update, I have installed the latest nightlie experimental - 33467 and everything works ok
Alright, thank you!
