Ive had max crash twice today on two seperate files when reaching the ‘Parsing the scene’ rendering stage when using corona. Small scenes. It just does nothing and im forced to crash out max.
I cannot send the files as they are work files and are confidential but surely its a renderer issue and not a file issue if it has occurred on two completely different files?
Jack
P.S. I Also note that this version is noticeably slower than the A7 release
Rendering at 1920x1200, i have 32gb of memory in my machine so i doubt its running out.
The scene is very basic. its a counter layout for a shop and it has less than 100k polys. It sometimes renders fine, ive had many renders from the scene, other times it completely crashes. It says parsing the scene but the progress bar stays at 0.
Yeah checking the cpu load and ram useage it has just frozen the ram and the cpu load is <1% so its a complete freeze. are there known issues with multiple lights in a scene? i have about 26 lights in the scene at the moment.
Please check the article again. I meant this part:
2. Reporting Error Messages
If you are experiencing a recurrent error that you are able to reproduce (for example a window shows up in 3ds Max saying “DEBUG ALERT”), please use this tool:
Process Explorer
When the error message appears, run the Process Explorer, find “3dsmax.exe” process (it is usually visible after clicking the + icon next to “explorer.exe”), select 3dsmax.exe and go to Process > Create Dump > Create Minidump… then save the file in a desired location and upload it to us using the Corona Uploader.
Ive narrowed this down to a single set of actions.
I Render my scene, its too bright so i go and adjust my lights. When i re-render it sticks on parsing the scene. I just tried to dump out the process but it caused an unexpected reboot. This seems like a pretty big problem…
It has happend in multiple scenes of diferent sizes. Step 1 i render the image after some material changes or something else. step 2 i stop the render. step 3 i adjust the lighting step 4 i render the image again. step 5 the render stops at parsing scene.
I seem to be getting this quite a lot recently too. Every test render has to parse the scene a few mins first. Odd thing is they were all rendering fine last week..no slow parsing..
I have same problem in all my project files. And I use only network paths because of network rendering. It freezes very often on main computer. Now I used to press save button before rendering.
But I’m wondering why application is not freezing on network machines if the problem in network paths…
The issue is probably elsewhere than textures (I had this bug in latest alpha daily where it occasionally go from 5 seconds to 5 minutes after 2-3 test renders).
I use only network paths (directly mapped though, not UNC due to simplicity) and since 1.002 have few seconds parsing even for 50 consecutive test renders (although I am still chilling if it won’t freeze…due to past behaviour).
I am using network textures yeah. I cant really change that though because if my scene is picked up by a colleague at any point they would have to manually remap them which would be a right pain. Im glad others are seeing this error too though and its not just my machine.
