3ds Max Error Vray GPU Light Cache Could Not Allocate buffer of Size 1865MB
Getting this error via 3ds MAX 2021
3dsmax adapter error: Autdesk 23.3 reported error: [GPU light Cache] Could Not Allocate buffer of Size 1865MB!
Vray GPU 5 Update 2.1 Submitted with Autodesk Backburner.
Any ideas on what is happening? Settings to adjust? Renders work locally but crash out on render server.
Hi @GeorgeKaplinJr
The error means you are running out of GPU memory
Did this scene render fine in version 5 update 1 ?
Check with update 2.2 that was released recently, it should handle memory better than before. And make sure you are on the latest 496 Game ready drivers
Best
Muhammed
Getting this error with 2080ti with 11 gb vram… also have 64 gb ram. what gives?
