Vray not rendering scene - error message "failed to allocate..."
Hello guys,
I am having a Max scene with very highres textures, and cannot get it to render via GPU, the following error message I am getting:
[2020/Oct/27|11:30:01] error: Failed to allocate 22020096 bytes, device 1, buffer default bufname
[2020/Oct/27|11:30:01] error: D:\cgrepo\vraysdk\samples\vray_plugins\rt_private\ rt_opencl_pri(3742) : CUDA error 2 : unable to allocate enough memory to perform the requested operation (out-of-mem)
Could this be related to texture sizes? I am using a RTX 8GB card in that particular machine…
Thanks,
Martin :wink:
Hi Martin
It may be exactly what you are guessing. Can you make sure that the GPU Textures are set to On-demand mip-mapped instead of Full-size and see if the issue persists? You can read more here: GPU Textures
We’ve also got a very detailed article on Memory Usage Optimizations for GPU Rendering, you might want to check it out.
Hi Nikolata,
thanks for your answer - that did fix my issue! Great!
Have a nice day,
Martin :wink:
Great to hear!
