I’m finding 3dsmax very painful to work with at the moment. The UI seems so slow to do simple tasks. I’m guessing it is 3dsmax and not Vray.
Simple things like going to graph editor and trying to add a waveform to a particular attribute can be a nightmare if you click on edit. It takes ages to open the menu which means you sometimes are not sure if you clicked it so you click it again and the menu flashes up and closes down quickly.
Other things like the material editor are so slow at times just to create a new Vray material inside a slot. These are just two examples but it’s unbearable at times !
I’ve just backdated the Nvidia driver to: 314.07 and so far this seems to have resolved all the issues including viewport freeze and then max forced crash every five minutes. Fingers crossed this is the solution…
