hey all i just restarted my pc and ive got again the same problem i am with 3dsmax2020 and when i close the X button the max is not responding even killmax and from the task manager wont help only restart to the machine help..
someone familiar with that? please any help ![]()
its happen only after i install corona..
If you’d uninstall only Corona, would that fix the issue? Could you try this?
you right its not corona..
im trying to figure it up right now i uninstall every 3rd 3dsmax components and still…
Hi yossioren113,
Sounds like a software memory issue or a windows error, things to consider:
Are you using scripts/plugins that start with 3ds Max?
Any 3ds max 2020 Service packs installed?
Do you experience the same issue in earlier versions of 3ds Max?
Make sure before fresh reinstall, to have registry clean from 3ds max & your app-data roaming auto-desk folder clean, also backup everything before deleting.
