Yesturday everything was absolutely fine, but today I get an error on startup (it stops loading files during startup on corona dlr) After uninstalling corona with Corona3dsmaxRemove everything returns to normal. tried few times to install and uninstall corona with same result, any idea?
Had this issue too. Yesterday all was fine. Today max start to crash on startup when loading corona.dlr. When uninstall corona - all fine, when install A6 - all fine, when install 1.0 or 1.00.01 - it crashes. Reinstall 3dsmax, install 1.0 - it crashes.
I solved a problem only by deleting folder: C:\Users****\AppData\Local\Autodesk\3dsMax\2014 - 64bit
After that it start working. It happened only on 1 of 3 my pc, others works fine.
yep… the same situation here. i’ve tried RC2/RC3/1.0 /1.0.01 and legacy version as well - still crashes. I’m sure I’ve copied all files correctly to right folders, as always.
I have to try your method, but first are you sure it’s safe to delete this folder? It contains subfolder called ENU, I thought it might be something important (about 120MB in there)?
Actually, if you haven’t deleted the previous folder, could you rename it back so that the issue is present again and see if deleting Corona folder helps? That could be very helpful for other users with this problem!
1 - when max crashes at startup because of “corona DLR issue”
2 - go to C:\Users\xxxxx\AppData\Local\Autodesk\3dsMax\2014 - 64bit\ENU\en-US\plugcfg\corona and delete corona folder (you might make a copy of the folder first just in case).
or
3 - go to C:\Users\xxxx\AppData\Local\Autodesk\3dsMax\2014 - 64bit\ENU and rename ENU folder to ENUOld, it works as well.
