3dsmax Composite map and color correction issue
hey,
I’ve noticed two bugs in both 2.6x and 2.7:
1. composite map: only the first layer is transfered to Vantage.
2. color correction map (normal, not osl) - HUE and SATURATION changes don’t transfer to Vantage.
Both things don’t work with livelink. I haven’t checked by exporting vrayscene.​
These should work, unless you are using them for bump, opacity or the environment.
For them, we have support only for bitmap textures.
Otherwise can you attach a sample scene for these issues please ?
Greetings,
Vladimir Nedev
Today everything works. Strangely enough, it renders in slightly different colors than yesterday, but the above-mentioned errors - work.
I am unable to reproduce the error from yesterday, when I also tried restarting 3dsmax, scene and even vantage update - but it did not work.​
We can close it.
Maybe it was some 3dsmax bug or idk
