5.2 rendering error
When I’m using SketchUp vray5.2, click rendering always makes a mistake that I can only use 5.1
Hi cq_x,
I’m very sorry to hear about your negative experience with the latest V-Ray version.
Please answer the following questions to help us understand what’s going on:
  1. Does the error only occur when rendering specific projects? If so, please share one of the projects that produce it for further testing on our side.
  2. Can you show and use the Asset Editor before you start a render?
  3. Do you have any other 3rd party extensions installed? Can you try disabling them and see if that makes a difference?
  4. Please share your system specifications and the rendering mode you’ve selected? Are you trying to render on the CPU or on the GPU (CUDA / RTX)?
Thank you in advance,
Konstantin
您好,感谢您回复我的问题,问题1:我测试了5.1版渲染文件,随着重新打开新界面并重置渲染设置,CPU RTX CUDA的各种参数都已调整或报告错误,还将光缓存调整为BF。错误总是我打开头发时犯的错误。问题 2:我可以在再次渲染之前打开并编辑资源管理器。问题 3:我没有安装其他会影响渲染的第三方插件,问题 4:win10 21H1。抱歉,我无法提供我测试过的文件。
I will continue to test after I am free, and will be informed of the findings with you
I’ll post a translation of your answers as a reference:
Hello, thank you for the reply.
Question 1: I tested with a file originally saved with version 5.1…
Question 2: I can open and use the Asset Editor before rendering.
Question 3: I have not installed any other third-party extensions or plugins that could affect the rendering.
Question 4: Windows 10; SketchUp 2021.
It is not currently possible for me to share the test files.
Can you please post the answer to question 1 once again since I could not make sense after automatically translating it?
Regards,
Konstantin
我测试了5.1版渲染文件,与重新打开新界面,重置渲染设置,cpu rtx cuda的各种参数都调整过还是会错误,还将光缓存调整为bf。
