7.3 question about node material editor
Before I update to 7.3, Is the new node material editor mandatory or optional?
And is Asset editor still available with same functionality as 7.2.02?
Thank you,
Glenn
You can still use the normal material editor on the Assets Editor.
You could decide if you want to use one or the other or both at the same time
Thank you for the fast reply & info.
Glenn
As @javierrentas said you can use both editors (using them at the same time is also possible).
By the way here’s a video showing the basic functionality of the Node Editor:
@konstantin_chaos
Thanks for the reply & excellent video.
To me it seems node editor will be very useful for complex materials, and asset editor for simple materials.
Glenn
