So I just got my brand new Nvidia 980 gtx card and I am want to start to use Vray RT.
I need to know how to setup Vray RT to use the cuda cores on the card. Is there a online setup guide to get me started with Vray RT? I have no idea where to begin.
I did that, and it rendered but I cant do anything in real time. IE change textures, lights etc. Thats more of what I am looking for. When I change the engine to CUDA and hit render I get an error message that says Vrya standalone has stopped working.
Which V-Ray build? Can you show me the output in the standalone command window? The GTX 980 requires a recompile of the GPU code, which older V-Ray build do not include. Other than that, I was playing yesterday with a 980 on my machine and it seemed fine with the nightly builds, so if worse comes to worse, we’ll get you that.
Hm, I just realized that the official builds do not support the Maxwell cards; it would be best to email us to support@chaosgroup.com for an updated build.
980 is a small chip (like the GTX 680), so it’s not the successor of 780. NVIDIA will release at some point the full Maxwell, which will be the real deal :).
Hi Everyone Im Mario and Im having the same problem with my new GTX 980, but Im also having this error while Im working some scenes with OpenCL (Image Attached)
Im working with Max 2013 and Vray 3.0 (with the last update)
I discovered this thing… If I place a single teapot for example in a cyclorama to do some material tests and put some other geometry stuff in my scene OpenGL works great…but if I want to see in RT a more complex scenes then I get the same error about the Stand Alone problem.
Please, if you know some news about this problem or updates to Vray please tell us. I want to solve this problem.
Thanks..
Greetings!
Peter, thanks for your time but CUDA isn’t working with nVidia’s Maxwell cards yet.
I attach you the error messages when I use CUDA.
I received a mail from Support telling me to ask at chaosgroup sales department a 3.X Nightly Access to be able to use GPU without any problem.. I sent the email today so I hope to get an update or something tomorrow.
There are some differences in the code when comparing CUDA and OpenCL, so it will be best to wait for access to the nightbuilds and try your scenes with CUDA (rendering will be much faster as well).
If it’s not a problem, you can send us the scene that crashes with OpenCL to try it here.
nVidia also recently updated their system so that beginning with Maxwell architecture and onward it should no longer be a problem to run older programs on newer cards.
