A small test with photon map
Here is a small test, it tooked 15 minuts with photon mapping + 6 minuts irradiance map + animation irradiance map with incremental 30 s, and AA for each frame 26 seconds, I will post as soon as it finish. :slight_smile:
exponential color mapping
http://www.gprospero.com/vray/tests/SR-01-HSV.jpg
a biger version with HSV exponential color mapping
Gonçalo
Beautiful, I can’t find one artifact. Looking forward to the Animation. Maybe you would explain to us us a little more your technique with the seperate passes. :slight_smile:
absolutely beautiful!!
would you mind sharing your settings?
HI Goncalo
HI Goncalo
as always great work
can I ask u as always some qustions about this work?
did u detach a little bit the walls from the ceiling? or from each other to get better corners?
thank u if u can and if u want to share your knowledge, please give some rendering and lighting settings
Bye and thanks for your great support
Wow GP!! Those corners are gorgeous.
Thanks for your coments! :slight_smile:
Here is the animation http://www.gprospero.com/vray/tests/SmallRoom2.avi
Eric: I ve reduce the number of passes to only one :slight_smile:
Pengo and Dynedain: I didnt use any trick, I ve only use photon map with a lot of photons…
The lighting is a solid color as background with Vraylights as skylight portals stored with irradiance map, and a Standart direct light with white color and multiplier 1.
And I will post the settings tomorrow
Gonçalo
Goncalo, the animation is showing up as blank black sreen. I’m using latest Windows Media Player with divx, 3vix, quicktime, xvid codecs all installed. Did I miss a codec?
Wow, so much depth and a rock solid solution. Very nice :smile:
there are some errors in the avi data stream. that’s why our players are having problems viewing them Brim, not a codec problem on our end, but on the encoding end.
take it into virtualdub if u really wanna see it.
thank u goncalo
thank u for the reply
bye and congratulation
Dunno why you guys had problems seeing it.. i downloaded fast and played ok even in full screen mode (WMP8+Divx)
yeah, plays fine for me too.
Brim try to upload the animation with max, in the computer I ve done the animation I cant see it either… :frowning:
Gonçalo
hello to everyone!
you need divx 5.05 at least…
with this version it worxs fine…
so long
man. :shock: thats super clean. great work G.
i’m running divx 5.1 pro. no can do for viewing here. if i open it up with a video editing prog (virtualdub, for instance) tells me that the stream has errors.
dunno, but the animation does look good goncalop :smile:
Goncalo please post the settings
Goncalo please post the settingsGoncalo please post the settingsGoncalo please post the settingsGoncalo please post the settingsGoncalo please post the settingsGoncalo please post the settingsGoncalo please post the settingsGoncalo please post the settingsGoncalo please post the settingsGoncalo please post the settingsGoncalo please post the settingsGoncalo please post the settingsGoncalo please post the settingsGoncalo please post the settingsGoncalo please post the settingsGoncalo please post the settings :lol:
EXCUSE ME BUt is so beautiful!! :sweat_smile:
I will post the scene, ok? :smile: give me some time…
Gonçalo
OK ecxuse me
OK ecxuse me
:sweat_smile:
:sweat_smile:
:wink:
that animation is absolutely beautiful
i ask about the settings because i’m fighting with a photon mapped scene :wink:
