hello mates,
i’ve been working at this bedroom, rendering it with photonmaps at secound bounce. Well i liked light, but as you can see, there are some blotches next ceiling and next windows.
Would like to know where could i improve to cut of this weird stufs
1. bounces and retrace bounces should be the same (like 10 or so)
2. retrace treshold better 0
3. check sore direct light, convex hull… and convert to irradiance map (!!!)
4. with search distance 50 and max density 10, many details will get lost. better use 10,2 oder even 5,1 deüending on how many lights are in your scene and how many subdiv. they have.
5. turn the subd. of the diffuse level of you light much higher (vray properties)
6. when storing the shadwos with irradiance map, then use higher smpling subdivs. (like 50-90)
7. better use lower multipl. for the light and use the colourmapping to get a brighter image
8. and watch over you units settings
just a few things for the start…goncalo, i hope you dont mind
here´s the testpic. i threw out the obejcts and placed in some dummies. there are a few problems with some materials of your objects. you use many standard materials which causes some problems with photons. better use just vray materials. i tested it with the original objects and the rendertime is not much longer, but it causes some spots. when you change the materials it will work. but the main focus was on the light settings and these can be seen in the file i sent you…and in the picture above. there are just 2 skylightportals and all multiplier are 1. as you can see the shadows are better know and i think even the colourbleeding and the ambient is more realistic, but that´s a matter of taste you will the receive the file per mail…
rendertime with photons, irradiance and rendering 12min
8)
Very good Improvement Metroberlin, could you post the settings to see the changes or better sill the file you used with dummy objects to see what did you to make the scene better?
maybe silver can post the file, at least it´s his scene…i can´t do that. if he wants to share it, fine…later the day when i have some time i can post the settings
hey marc, thanks again and again and again :lol:
if you want, you can post the whole file, because the same way i want to learn more, i want mates improve your knowledges, that’s no problem for me, but i guess should be better you post the file because i havent a server for that, i can post only images
will try to make some corrections at the file and post again here
