aaouviz bug list
As I don’t have access to post in the Bugs forum I’ll put my long list of issues here;
11/05/2017
- I press render and go to chrome (or any other program) to browse; only to have the VFB appear on top suddenly, so I close it. It reappears soon after, close again, then it reappears for a 3rd and final time. It dominates the screen and continually readjusts its size.
- The bloom + glare is still completely buggy - sometimes refuses to work saying channel not rendered. ‘Intensity’ doesnt work at all *** I think the bloom + glare bug is fixed by resetting visoptions to default then rendering (perhaps this was an old file which I continued to use thru the beta process)
- The visible buckets when rendering with swarm is a problem (discussed here: https://forums.chaosgroup.com/showthread.php?91833-Bug-Swarm-buckets-visible)
- No prompt when copying in an existing material - end up with many duplicate materials - horrible for library asset management
- Crashes when switching to/from GPU/CPU renderinng
- Cannot do batch renders properly as the depth of field isnt auto like it used to be
- Occasionally get ‘locked’ in material editor when editing a texture (back button doesnt work)
- After a big render Vray/Rhino doesn’t close properly when I shut down my PC - this means all my rhino default UI is reset every time I re-open Rhino
- Many many instances of ‘vray nuei’ in task manager - what is this? Shouldn’t I get 2 instances of this total?
- Explorer pop-up for BMP file section always appears behind vray asset browser - incredibly annoying
- I don’t know if anyone else has this issue; but using commandline shortcuts doesn’t work about 50% of the time, I have to click in the command line for Rhino to understand that I want to type something. Sometimes this takes multiple ‘clicks’ its as if there is an invisible window on top (i heavily suspect vray to be the offender here) of rhino taking preference.
- The system behind the VFB rememebering the Corrections Controls is not understood. Does it remember the last used settings, does it remember based on files? This causes major problems as I render once on job ‘A’, later render on job ‘B’ with exposure adjusted, then when I do a re-render on job ‘A’ it has different settings to the first render
- Right clicking on a material in the list makes it ‘active’ but isn’t highlighted - this is confusing!
- Mateial UI; Apply to layer is still incredibly difficult to use!
- VFB randomly saves all render elements when only one was asked to be saved - this is random and I am yet to figure out what triggers this *** I think this might be fixed by resetting visoptions to default then rendering (perhaps this was an old file which I continued to use thru the beta process)
- region render fails if i have previously done a visrenderblowup
- if i do region render and close rhino + vray, the next time I open rhino + render the red region square is visible but not in use
Do you still experience the following issues:
- “Crashes when switching to/from GPU/CPU renderinng”
- “Occasionally get ‘locked’ in material editor when editing a texture (back button doesnt work)”
- “After a big render Vray/Rhino doesn’t close properly when I shut down my PC - this means all my rhino default UI is reset every time I re-open Rhino”
If you do, then any additional info you can share would be appreciated!
I’ve missed the opportunity to reply before, but thank you for organizing this list!
Kind regards,
Peter
Hi Peter,
No worries. Appreciate the reply!
I don’t think any of these 3 problems occur any longer. (Of course, I may have just found ways to work around them/ignore them and now they’re not on my radar, but from memory these don’t seem to be an issue.)
I’ll let you know here if any of the issues listed do persist.
Cheers,
Been working on a file for a couple of months - suddenly I can’t invoke the asset editor. I can render and so on, but the asset editor will not show… Any ideas?
Apologies for the late reply!
Do you still experience this issue? If you haven’t contacted support@chaosgroup.com yet, please send us an email with details about your PC specs and full version number of V-Ray for Rhino so my colleagues can assist you accordingly.
Kind regards,
Peter
