ACES again
Im beyond confused. Those settings in the docs here arnt possible the dropdown doesnt show that and its the other way around in the Maya 2024 prefs.
I think the docs are still covering aces 1.2
Currenty Maya should be OCIO 2.0 (or 2.1) with aces 1.3
you could always go with a custom ocio config and a environment variable pointing to it.
the good thing is, that every app is using the same config then.
