Looked through the documentation and discussions … and have also done some personal benchmarks.
Verifying what is the advised general settings for day-to-day stability and performance with Enscape (we are using it for both Revit and Enscape).
- Is it advised to generally have ‘Hardware-accelerated Ray-Tracing’ and ‘Ray-Traced Sun Shadows’ enabled to start?
- Do enabling these two options substantially affect performance … such as:
- causing GPU memory to run out for larger scenes?
- causing GPU to be taxed more and produce excessive heat (though its within thermal threshold, our mobile workstations are already running warm-hot with Enscape = warm keyboards)
- cause Enscape framerate / navigation performance to drop (similar to when Ray-tracing is enabled in PC games)
- I have seen in discussions that enabling these ray-traced options as the resolution for light leak issues (especially on later version of Enscape).
Do you anticipate this becoming more of an issue … and should most enable these ray-tracing options by default due to this?
Weighing the pros and cons with advising all our users … if these ray-tracing options should be enabled or disabled by default.
Thanks for any guidance / clarity on this!
- Ed
