Known issues:
“Affect shadows” and “Affect alpha” options do not work for VRayMtl’s inside a Multi/subobject material. This will be fixed as soon as possible.
I’m a big user of multimaterial for my frames + glass, so i’ve not switched yet to 1.5 RC3 because of this.
My question is: do we have to wait 1.5 RC4 for this to be fixed, or does it has been fixed already in the actual RC3 build ? (i can’t wait to have a vertical shift guess in vRay cams )
RC3 is still broken in that sense, however you can get around it buy wrapping your glass material in a vrayblendmtl and then stick it in your multisub.
hmm, I am eperiencing that on an interior shot. I am using vray suan and sky to illumiate the room, vray cam and muti sub object materials for different types of glass in a frame, i want to have a alpha info so that i can drop actual photos so that they can be scene through the windows, but I dont get any alpha info…
i have affect alpha ticked, and a multi material with the vray blend material wrapping the id’ed vray material… no joy though…???
oops that was me trying to get it to work… tried without.. same..
here are some other problems… i have a floating glass floor, you can see if i remove the geometry with the glass you can see the thinkness of the inset floor, the second image is withough the glass floor geometry.. adn you can see the thinkness of the floor..
As for the other problems, those images just confused me.. I dont really know what im looking at.. :lol:
If you can explain what im looking at I might be able to help you..
Ahh, if you want, upload a part of the scene (rapidshare.com) and I can have a look at it for you.
look at what appears to be a eliptical blue floor in the middle of the image, in the first image it has no thinkness, in the next image it HAS a thickness as the glass ‘halo’ floor has been removed..
anyway think i have it fixed.. IOR now set to 1.0 for the glass.
still not gettting a alpha.. will look at the fix thread.. sure i read it as i did now that it was a reported prob…
ahhh yes, thats right your after alpha not shadows.. doh!
Yes, well it appears that your stuck.. ummm if you need the fix urgently you could try to email vlado and request the fixed build. You will need a good reason tho.
