“Known issues:
(*) “Affect shadows” and “Affect alpha” options do not work for VRayMtl’s inside a Multi/subobject material. This will be fixed as soon as possible”
Lukx is coming with help
If you still need to use for example glass in mulisub material first create vray blend material and as base material put this your material in which you need to use affect shadows. That’s it Affect shadows will work. I didn’t check affect alpha cause I never use it.
