AI enhancer
So is there a way to use images rendered larger than 4K in the AI enhancer? I have rendered some images at 7000x3938 through the backburner. To get them into the enhancer I load them into the history in the VFB and resume render. As soon as there is a pass rendered I stop the render and upload the image to the AI enhancer. This all works but when I open the image in the project the enhancer is not available?
Edit: I successfully did this with an image of 5400x3375. The image was automatically downsized to 4k but somehow that doesn’t happen now.
Edit 2: I also noticed that the image that was successful was uploaded as an EXR file, the ones that I upload now are png iles?
Edit 3: as soon as I save the CXR at 50% resolution it gets uploaded as EXR and the enhancer becomes available.
If an image is larger than 4096px then it is automatically downsampled to 4096px and then enhanced, as explained here Corona VFB 2.0
How exactly are you uploading your renders to the cloud? Are you using the AI Enhancer button in the VFB? I don’t think other methods are currently expected to work, such as manually uploading an EXR/CXR file.
Yes I am loading the image into the history and then use the AI enhancer button, but it won’t downscale the image.
Ok, thanks for the details. We will look into it.
I am also getting very mixed results. I have attached some examples. The first 3 have all got worse after the enhancer. The last one actually improved. So it seems to be hit or miss with the enhancer. Foliage and plants seem to work the best.
Foliage and faces can get better as seen in example 4, but all the other results are useless. Example 2 and 3 are really bad compared to the original.
Something is definitely wrong here. The Enhancer should only enhance faces and vegetation, and it shouldn’t produce ugly results like that. I guess in this case it is not using the special render element which masks different objects.
Well, I can select different objects in the enhancer so the render element is there. I also noticed that in a previous version (lower resolution) I was able to select more vegetation than in the high resolution render.
Is there anything I can do, or is this being looked at?
The more I try the less I understand about what is going on. I render the same file, one local and one through the backburner. The local one only let’s me select 2 people out of the 6 that are close enough to the camera. The backburner one (after I save it to a 50% file) let’s me select 5 out of 6 of the people. Both files won’t let me select any vegetation, and the initial enhanced image looks like garbage, it will only look good if I manually select people and enhance them through the menu that pops up that let’s me change age and gender.
Hello Maru, are you looking into this or am I doing something wrong? I would like to know if it is on my end or your end.
Hi Erik, sorry for the delay, I have just started a support ticket #441904 for you. Please check your email.
