Where can I find the new AI Image Enhancer?
Hi there,
You can find it right in the VFB 2.0
But first, make sure to add the AIEnhancer Multipass, as it has the data needed by the AI enhancer.
Have fun with it.
Cheers.
Thanks guys!
Hi Atlantis,
I tried this today and had the same trouble, but I missed the obvious and hadn’t enabled the multi-pass as I thought it would automatically do that for me.
It seems to work when starting a new project, but not if I open an older project.
Your resolution is to high. Currently AI enhancer can be activated only if the render resolution is within 512-2048 px range.
Ok, that makes sense
I also tried that but I don’t get the menu item “Enhance Image” in Chaos cloud as shown in the help file.
Do I need a different subscription for that to work? I have “Corona Premium”…
For diagnosing - You have the new Render Element added? You ran the render again with that new element, so that it gets generated? Immediately on render completion, did you send the image to Chaos Cloud using the new AI Enhance button, rather than a standard upload to the Chaos Cloud (e.g. the old way is how you’d do it for Collaboration or Virtual Tours)? What would be best for us to help out would be a screen recording of you showing the scene set up, including the render elements, how you upload it, then what you see on getting to the Cloud, which would be best sent in via ticket at Chaos .
By “Render Element” you mean the “AiEnhancer” Multi-pass, right? If so, then yes!
I have rendered it and used the “AI-enhancer-button” in VFB to upload the image to Chaos Cloud.
I have just made a screen recording and opened a new ticket.
Thanks for your help.
Thank you for sending in a ticket, with recording attached! That will let the support team dive into your issue and find out what is happening.
