alembic sequence not working
when using an alembic sequence (filename.$F.abc) in an alembic sop, vray will only use one frame/file of the sequence.
See attached scene.
vray_seperate_frame_abc_issue_v01.zip (34.2 KB)
Could you please use $F4 for now as a workaround? I’ll try to fix this asap though…
With Alembics you might wanna check out writing out the whole sequence in one file - that’s how many of the Alembic features are meant to work, like saving the geometry and transforms separately, retiming, etc. You’ll get smaller files too.
@bdancer : ah, great. I usually use $F4, so no worries. Actually have no clue why I didn’t this time.
@glacierise true, but I want to distribute fluid meshing and write it directly to abc.
Yeah for fluids you don’t gain much by keeping in a single file :slight_smile:
