VRayProxy loading an Alembic sequence?
we want to load an animated alembic (file.1000.abc, file.1001.abc, etc) sequence into a VRayProxy node. But it doesn’t work. The proxy node always loads only one file and if we replace the frame number with #### (like it works in 3ds Max), we get an error message “file is empty” (see screenshot).
Please tell me that we just make a little mistake and that this is no problem at all!
TIA
Lars
Synthax is different. It should be <frame0n>, where n is the number of digits (in your case 4). Check docs.
Lucky! Thanks Aleksandar! I really was sure that we had RTFM :sweat_smile:
