alpha channel vray gpu grasshopper not working
So have a simple wrapper material for a background..if i render with CPU the Alpha shows fine, but if i select gpu-..it doesnt work.
Any solution?
Screen shots of relevant information would be useful, like CPU vs GPU output for visual comparison.
solved.. gpu alpha only works with matte disabled for secondary and then cpu works in both scenarios.. thanks.
Hi @citro3101 ​,
Also note that with V-Ray GPU the indirect light is not affecting matte surfaces.
