Why is there a difference between alpha channels when rendering with vray sky?
Here is an example: same scene one lit with invisible dome, the other with sky in the 3ds max environment slot - each render saved as .png with alpha included
The alpha included with the sky render is different than the alpha rendered with the invisible dome light…
edit: I just noticed that if I put the sky map in the vray render “GI environment override” slot that I get the same alpha…
I guess this solves my problem… just curious why the alpha channel gets bloated by a pixel or two when the sky map is in the 3ds max environment slot vs. the vray GI environment slot in the render settings panel… (and I searched for a solution to this on the forum and didn’t really find the answer I was looking for so maybe this is helpful…)
