Hey, I am having a problem while I am rendering certain animation through backburner ( MAX7). On one computer I’m getting this overburned image while others computers render just fine. all installation of Max7 are same. Does anyone have any idea what’s going on ?
sure - there are lights in the scene. It doesn’t have anything to do with the scene itself I guess because if the same frame is rendered on other render slave it is correct.
the problem is SOLVED. It is again the numbers separator in Windows - crap - this problem dissapeared with Max 6 and it went back again with Max 7 - I really hate these type of problems. Anyway thanks to all for their replays.
it means - that if you have in Windows Control Panel/Local language settings set as the number separator “.” ( it is default in english versions of windows ) and on some computer(s) you have the separator “,” ( we have that as a default in our language version of windows - Czech ) - rendered images from one sequence will be different - it is old known issue which unfurtunately comes back again.
