how can i use the new anaglphy preview function in the VFB ?
If you render two side-by-side images using the VRayStereoscopic helper, you can enable one of the anaglyph previews in the VFB to merge the two views in one image.
This is in fact a huge time-saver. It replaces the old “render in vray, go to nuke, check, come back to vray, render, nuke, etc”. Works great! Now make it compatible with nvidia 3d vision and it will be bliss.
hi
i still cant find it
dont know how to active anaglyph in VFB
any help?
in “helpers” click the dropdown and select “vray”. Here you will see the helper you need.
huh?
i use the stereoscopic plugin,
but it says
it can do anaglyph preview in VFB
the new vray update says it has anaglyph preview in VFB, i dont know how to activate anaglyph preview (to be used with red-cyan glasses)
thanks!
“If you render two side-by-side images using the VRayStereoscopic helper, you can enable one of the anaglyph previews in the VFB to merge the two views in one image.”
what do you mean
how can i merge them, how can i see anaglyph in VFB ? (red-cyan glasses needed)
please tell me ![]()
ok reinstalled vray now i see the anaglyph button in VFB
Hi, is this anaglyph preview still available in Vray6? Can’t seem to find the anaglyph preview button.
Sorry to say, we’ve not yet implemented it in the new VFB2 (internal bug-tracker id: VMAX-12301). I’ll bump its priority.
