Animated Proxy Rendering with Black bits
When I render out the scene with the animated proxies, they have black bits on them randomly flickering from frame to frame;
http://www.inlightin.co.uk/images/Proxy%20Mess.jpg
Apologies for the small image bit the strange thing is that when I render at a higher resolution, the black bits get smaller but are still there.
Has anyone come across this ?
Thanks for any help.
N
I am unable to view your image…
Thats a bit strange, anyway, I hope this works.
Any ideas would be helpful.
what GI methods are you using?
Irrad map and LC.
There are alot of settings and little techniques that I am using so, what specifically are you referring to ?
Im just wondering if using a single frame GI approach will clean that up
I tried pre calculating each frame and it helped, I think there are a number of factors that caused the problem and there is no one thing that I can say has solved it.
It either happens or it doesn’t.
As soon as this project is over, they are getting binned.
wait. your saying you used a precalculated map on a moving object?
yes i believe your right :wink:
Believe it or not but, I used the method for a static animation and it worked brilliantly but you have to make the moving objects not visible to GI.
For no good reason all of a sudden these black bits started to appear after numerous successful tests.
The black bits still show when I render still images with their own Irrad and LC solutions so, the method above can’t be the cause. Also, when I render the image at 3000 pixels - the black bits are still there but alot smaller.
Its all very confusing.
Ok - the solution to get rid of the black bits;
Untick ‘Check Sample Visibility’ in the Irrad Map rollout.
Can’t believe that caused me so much hassel.
