hi,
I have to make an urgent animation for a client and when i want to render my animation, vray make just one picture.
I copy all my 3d in a new sketchup file and it’s works fine but just one time.
I can’t do this all the time because it’s big file.
What’s the probleme?
Sketchup 2018 and vray 3.6
Hey there:
Can you tell us more detail?
Make sure in Sketchup animation settings (Model info)
Scene Delay is set to 0.
for example:If Scene delay== 5 sec, you will render 5*30=150 frame on the same location.
Yes, scene delay is set to 0.
I tried a new test this week-end and it’s work fine.
It’s weird!
One thing i don’t understant with animation in sketchup.
When i set transition scene to 1, vray don’t render 30 frames/second?!! when i render my animation with 10 scenes, finaly i have 10 frames!!
I test many things and i noticed when i set transition scene to 24 s, i have 24 frames. set to 10 s i have 10 frames!
I lost my time to understand the operation of vray animation,
V-Ray hardcodes the frames per second to a value of 30. This means if you set a 1 second animation you get 30 frames, 5 seconds - 150 frames, etc.
The Animation frame range only specifies what part of the whole sequence you wish to render, e.g. if you set the “Start” parameter to 18 and “End” to 25 in a 1 second animation will render only those specified 8 frames out of all 30.
If you change the Animation length through SketchUp’s controls, you can update the frame range numbers by clicking the “Get Animation Range” button in the V-Ray Asset Editor.
https://docs.chaosgroup.com/display/…tput-Animation
Kind regards,
Peter
